Rear LS1 brake swap.
Old Oct 2, 2003 | 10:59 PM
taqwache's Avatar
Default Rear LS1 brake swap.
has anyone ever tried to swap LS1 rear brakes to a 8.5 axle axle out of a 2nd gen Camaro. i measured the bolt holes for the rear brake mounts from my 02 SS and my 69 SS (which has a 2nd gen 8.5 in it) and they look the same. i dont what to but a set of rear brakes and find that it will not fit. it would be nice to have inexpensive rear disk on my 69. please help.
Old Oct 2, 2003 | 11:15 PM
67LS1T56's Avatar
Default Re: Rear LS1 brake swap.
TGhey do fit. I got them.
Old Oct 3, 2003 | 12:49 AM
taqwache's Avatar
Yes!!. that was the answer i was looking for. was it just a bolt in deal and also was the caliper evenly space on the rotor? Thanks, Steve.
Old Oct 3, 2003 | 01:15 AM
66ImpalaLT1's Avatar
I think they work depending on the shock placement.
Old Oct 3, 2003 | 06:18 PM
gEtyOPaPiOn's Avatar
IF YOU HAVE STAGERED SHOCKS YOU NEED TO GET 2 RIGHT SIDES FOR IT TO WORK ....
69 LS1 Camaro project
Old Oct 4, 2003 | 06:56 PM
taqwache's Avatar
do the shocks get in the way. i was going to go with coil overs anyways but the main thing is that i wanted for the parking brakes to work properly. if i use two right sides, then wouldn't the left side parking brake cable be backwards?
thanks steve,\
Old Oct 5, 2003 | 10:07 PM
PARKING BRAKE IS ANOTHER STORY BUT YA WILL FIGURE IT OUT ONCE THEY ON
