msd 6010 box questions
regards
I'll kill you off the line. I would'nt be surprised if the low initial timing is'nt the reason so many of you are encountering the stumble off idle that so many of you complain about all the time. If you would take a look at the instructions that came with your 6010, you would see that most of the timing curves for the pills that come with it use more initial timing. One of them has something like 32* @ 800RPM. All of them have at least 20* @ just above idle. I have seen numerous dyno tests in various magazines using these "pills" with NO problems. The Car Craft engine that everyone seems to want to duplicate ran 32* of total timing. Just my .02 cents worth. And by the way, it adds timing any time the throttle is opened just like hooking it straight to manifold. The difference is, you don't LOSE your initial timing like you do the other way.
I could not have said that better. Thanks
I've got my car strung out all over the shop, trying to put in shoulder harness, and some other stuff so I can run this summer. We are just getting out of a really BAD ice storm. I've even got a heated shop, but I still can't seem to get motivated. Ron
