Help, fox motor mounts just started
93 COUPE QA-1 K-MEMBER FOR 98 NEWER STANG, 4.6 COBRA MOTOR MOUNTS.MOTOR MOUNTS BOLT UP DIFFERENT THAN 5.7. MADE ADAPTER PLATE FOR MY 5.3. MOTOR SEEMS TO FAR BACK AND TO HIGH IS THIS NORMAL NEED PICS OF MOTOR MOUNTS. TRANNY IS 4L60E SEEMS TO TIGHT IN TUNNEL. I WANT POLY OR RUBBER MOUNTS. SOLID WOULD BE EASY, BUT I DONT PREFER
THEM FOR THE STREET.
I HAVE SEARCHED HYBRIDS.
IDEAS?
Jamie
jfg455 seems to have the better solution for custom motor mounts.
jfg455 if you have anymore pics, especially firewall and tranny pics it would be appreciated. Was your build an automatic.
The 4.6 mounts place the engine to close to the firewall and the 4l60e to high in the trans tunnel. I would not waste any time on them fab your own like jfg455. I wasted a couple days trying to make the 4.6 motor mounts work.
If you still plan on attaching the 4.6 mount to that block let me know I'll get you a picture of how i did it or draw something out. It also moves the engine forward giving you more clearance the way I did it. The Best V8 Stories One Small Block at Time
can you shoot me a pm on please because ill most likley be using a 5.3/th350 set up,are the mounting locations on the 5.3 vs the 5.7 that diffrent on the block?
