LT1 to LQ4 swap
Also has anyone every piggy backed pcm's to keep my dash and bcm and abs and tcs functional?? I want to run the engine off the LQ4 comptuer and everything else of the stock one. Would it only be putting another temp probe in and wiring up a power and ground to the other computer and splicing into the crank sensor for tach??
I built my own Harness for my swap and it works without a problem.
Here is my swap thread..
https://ls1tech.com/forums/conversio...to-95-z28.html
