fuel rail help
Old Jan 25, 2009 | 07:06 PM
crazygn's Avatar
Default fuel rail help
i bought the corvette fuel filter reg. Now do i need the fuel rail that has nothing on it or can i use the one i have that looks to have a fuel pressure reg already built on the rail
Old Jan 25, 2009 | 07:34 PM
poconojoe's Avatar
If it is a returnless rail you can use it, The thing you see on it is most likely the pulsation dampener. Returnless rail only have one fuel line connection on them
Old Jan 25, 2009 | 08:37 PM
crazygn's Avatar
great iam good to go then , thanks for the help
Old Apr 5, 2009 | 12:00 PM
JRocket's Avatar
So I assume that the regulator looking part on the 01 camaro fuel rail is actually a dampener,not a regulator?The regulator is in the tank on the pump correct?
