EFI fuel line, single or double flare?
Old Jan 28, 2009 | 12:54 PM
garys 68's Avatar
Default EFI fuel line, single or double flare?
I'm planning on using a Walbro pump and vette fuel regulator at that gas tank.
From there I was going to link up using the existing 3/8" hard line to the front of the car.
BTW, I'm aware of the differences between JIC/AN/SAE/45/37, etc fittings.
My question is at under 100psi, does the steel hard line need a single or double flare?
Old Jan 28, 2009 | 01:00 PM
jbsjunk's Avatar
I always double flare my lines and it's mandatory for brakes, but lower pressure fuel lines may not be a problem. If you have the flaring hardware I would double flare it.
Old Jan 28, 2009 | 02:46 PM
oange ss's Avatar
no reason to DF it if you dont have to, could cause problems especially if you are using SS line
Old Jan 28, 2009 | 03:20 PM
poconojoe's Avatar
Double flaring will give yoy a much sturdier connection. You have more of a chance of a single flare going bad and breaking, then a double flare.
Old Jan 28, 2009 | 04:18 PM
ryanvv355's Avatar
I use single flare
Old Jan 28, 2009 | 04:23 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Its double flare steel tubing and single stainless
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
