Advice Needed
Old Feb 9, 2009 | 03:47 PM
oxfordm5's Avatar
Default Advice Needed
Hello , i am doing a ls1 +t56 swap into a g-body that had a lt1 conversion already in it. i have been searching for the past few days and have got a lot of answers to my ?'s
i am getting a good deal on a 1999 ls1+t56 from a camaro 90.000 mi from a junkyard the setup is still in the car and i want to make sure i get everything i need in addition to the harness and ecm is there anything else i should ge t
Thanks
Old Feb 9, 2009 | 08:10 PM
bczee's Avatar
Question, are you worried about Smog law and being compliant ?.. if you are, I would suggest you make sure you get all of the related items right down to the Fuel tank sensors.
But get everything you can starting from the Radiator and fans back. If your going to use some of the other interior dash parts, get the BCM and harness also.
