speedometer
Old Feb 11, 2009 | 09:43 PM
sum guy's Avatar
Default speedometer
I just hooked up my autometer tachometer to the tach output wire. It works but it reads alot lower than the engine is actually revving. I did not cut any of the wires per the v-8 hook up. Letme know if any of you have run into this.
Old Feb 12, 2009 | 05:03 AM
LS1MCSS's Avatar
If it's connected to an LS1 pcm, the signal to the tach is probably a 4 cylinder signal. That's what the factory setting is. It can be changed with programming or you can change the tach wiring.
