External measurements and weight
Old Oct 13, 2003 | 08:49 PM
93LS1Mustang's Avatar
Default External measurements and weight
Hello anyone with help.
I need general specs for the outside dimensions of the LS1 engine, bellhousing and six speed trans.
Can anyone tell me where this info could be found?
I want the width(width of cyl. heads @ exhaust ports), length(front most pulley to back of cyl. head), and height(btm of oil pan to top of intake) of the engine
I also need the diameter of the bellhousing and how far the bhousing is above the bottom of the oil pan.
I am researching a project of putting an LS1/six speed in my new Saturn ION, and converting to RWD.
Thanks, Derek
Old Oct 14, 2003 | 04:30 AM
jaberwaki's Avatar
Default Re: External measurements and weight
dont have the specs but keep us updated that would be a light powerful sleeper right there!!!
Old Oct 14, 2003 | 07:14 AM
LS1swap's Avatar
You should try the hybrid section...... I remember a thread on that lately. I think you will get your answer over there. If length is a factor.... You may want to consider a Y- body crank pulley. They are 3/4" shorter than the F body ones.
