5.3 in 99 camaro, which starter?
Old Mar 2, 2009 | 10:15 PM
sman's Avatar
Default 5.3 in 99 camaro, which starter?
Do I want to use a 5.3 starter or the ls1 starter? I wasnt sure if there was even a difference, so I have to ask. I was just going to get the 5.3 one but I wondered if id have clearance issues or something in an fbody, or if it was compatible with the ls1 harness.
Old Mar 2, 2009 | 10:24 PM
LQ9CHEVELLE's Avatar
The LS1 starter and the 5.3 starter will bolt up the same, but for some reason the LS1 starter has a short bolt and a long bolt. The truck starter takes 2 long bolts. Ive used both on 5.3's with no problems, but maybe the short bolt LS1 starter is for a chassis clearance issue in F bodys. I dont own a Fbody so i have no way to check, but if the 5.3 starter fits in your chassis you can run it
Old Mar 2, 2009 | 10:38 PM
sman's Avatar
I have no idea if it fits or not, I would guess I should probably get the ls1 starter then correct?
Old Mar 3, 2009 | 12:21 AM
officerobrien55's Avatar
may not be same but all bolt the same truck one is probley bigger
Old Mar 3, 2009 | 09:21 AM
Truck starter is same size....just the casting on the ls1 starter mounting area "steps up" where the outer of the 2 bolts are, and uses a short bolt. Other than that, housing, solonoid are the same size
Old Mar 3, 2009 | 10:10 AM
sman's Avatar
Do starters normally include the mounting bolts? If not what size do I need?
