68 camaro lq9 header question
Old Mar 5, 2009 | 10:22 PM
s4dustin's Avatar
Default 68 camaro lq9 header question
I am looking for headers for my camaro. Pushed the engine back 2.5 inches. Are there any off the shelf headers that will work? I know Edelbrock makes ls1 swap headers....great value, but I am not sure if they will fit since I pushed the engine back. A friend suggested that since I am using a t56 out of a 2002 camaro, why not get ls1 headers for a 2002 camaro and modify where needed...or perhaps they will work.
To get headers made, it will cost $1200 bucks....I paid a grand for my lq9, 800 for the t56...and I cant imagine paying more for headers than an engine or trans.
Any thoughts here guys>
Old Mar 5, 2009 | 10:55 PM
01cherryreds10's Avatar
I know summit racing sells a kit where you can build your own, but that can be quite labor extensive. Current performance wiring swapped a 4.8 into. 72 cutlass and they used a set of TBSS manifolds they had laying around. I'm not really sure what else can work though sorry.
Old Mar 6, 2009 | 06:28 AM
69LT1Bird's Avatar
2.5 in. from the stock Camaro position I am guessing, this is normal.
I have the hooker headers made for the first gen F car and they fit great, they clear the steering gear with no issues. My engine is very close to the firewall, maybe 1 - 1.5 in. I made my own motor plates and just used 69 Camaro mounts.
Old Mar 11, 2009 | 12:03 AM
aray327's Avatar
Not sure how you were able to push the motor 2.5 inches unless you modified the firewall. Anyway, my 69 camaro LS motor is pushed back about 1-1.5 inches which puts the head on the passanger side about 1/4" away from the firewall. Headers on the passanger side are no issue. I used Street and Performance short headers because my car sits low and I didn't want to scrape the collectors any longer. I had to dent the driver side header in two places to clear the steering box. Because the flat spot is behind the steering box you can't even tell.
