Routing Steam Vents
Actually I'd like to see some photos of how you managed the routing of your steam vents from the head, and what fittings you may have used.
For my application, I have turned my intake 180 degrees for a mid engined application. Also, I made a tensioner bracket that is positioned directly in front of the steam vent fittings, so I'm working in a very tight and limited space. I did get some Wegner steam vent adapters that basically have a 1/8f'male NPT on them so I can adapt to just about anything. In the attached photo it shows a modified stock vent setup (barely visible), but it just won't work for what I want to do.
Many thanks,
Andy1
