99 fbody k member bolt problems
Please help!
I'm not real familiar with that body style, but you may be able to access the broken bolt by making a hole saw cut from the side or the floor if it goes back that far and grab the bolt from the inside and turn it the rest of the way in till it's out then chase the mount hole with a tap to clean the threads.
I've used both of these methods in removing broken body mount bolts on trucks I lift.
Good luck.
