Air Charge Temperature Sensor
Old Mar 14, 2009 | 01:41 PM
ral_fradet's Avatar
Default Air Charge Temperature Sensor
im putting a ls1 into an a body and i noticed a plug that was missings its sensor and i looked it up and i think its the air charge temp sensor, so i was wondering if its required or if i can delete it on the computer (i will be using hp tuners).
Old Mar 14, 2009 | 05:57 PM
the_merv's Avatar
Veteran: Air Force
Depends on what MAF you use. It is a required Sensor, helps with the Fuel trims.
Old Mar 16, 2009 | 12:37 AM
tails8's Avatar
^^ Ditto what he said. I wouldn't tune it out. Was the wiring harness missing the actual connector or is the actual IAT sensor missing? If so just head down to autozone, checker, etc.., and get another one..
Tails
