aftermarket speedo on 4l80e
Old Mar 16, 2009 | 11:41 AM
726.0chevelle's Avatar
13 Second Truck Club
Default aftermarket speedo on 4l80e
I am hooking up my speedometer to my 80e which is an 03 model my speedometer has two wires that both say from pulse generator my harness has one wire that says to speedo. I called the gauge manufacturer they said do not hook the two wires up to the harness but hook them up to the speed sensor i told the tech that an 80e has two speed senors but he assured me that it has only one so what speed sensor should i hook the two wires up two? This is a programmable speedo if that helps, any help is appreciated
Old Mar 16, 2009 | 02:35 PM
forcd ind's Avatar
hook up to the rear sensor-i guess your not using the stock chevelle speedometer
Abbott makes a cool mech speedometer converter i used on my 4l80e for the chevelle, its pretty accurate too-someone on ebay makes has a sensor pigtail that i got, if you dont have one
Old Mar 16, 2009 | 06:22 PM
ill have to try that. where is a good spot on the block to get a good oil pressure reading im trying to use the supplied sending unit
Old Mar 17, 2009 | 06:37 AM
forcd ind's Avatar
the stock sensor for oil pres was in the back near the cam sensor i think-i drilled & tapped a hole down by the oil filter for mine, i use mech gauges
Old Mar 18, 2009 | 07:58 PM
anyone else?
Old May 1, 2009 | 12:52 PM
hookemdevils22's Avatar
bump for more info. looking @ hooking up electronic autometer gauges to my LQ4/4L80e setup... any help is appreciated.
Old May 3, 2009 | 11:12 PM
93ND500's Avatar
I used an end housing modified for the 4L80E to drive my Autometer speedometer. Here is the link. http://www.shiftworks.com/tailhousing.htm
It's just a little more than half way down the page.
Old Sep 3, 2009 | 02:47 PM
BlackTA96's Avatar
Anyone have anymore info on this????
