Fuel pump wiring
Old Mar 21, 2009 | 01:00 PM
brianjw4's Avatar
Default Fuel pump wiring
Are you guys running fused links from the pcm to the fuel pump or using a relay? If relay, does someone have a wiring diagram for this?
Old Mar 21, 2009 | 01:13 PM
LS1GMCTruck's Avatar
Definately use a fuel pump relay. #10 red wire from the alternator stud to the relay for power. Fuse this wire near the alternator end. Relay is triggered by the computer.
Old Mar 24, 2009 | 12:46 PM
crainholio's Avatar
And if I recall correctly, the PCM provides a switched 12V to pull the relay. Unlike the fan relays, where the PCM switches ground.
So the relay will have:
10ga 12VDC in from fused battery source
10ga 12VDC out to fuel pump
14ga (?) 12VDC in from PCM
14ga (?) to chassis ground
Old Mar 25, 2009 | 09:25 AM
Default Fuel Pump Relay Amperage?
Yes. And I forget crainholio...does this call for a 30...or a 40 amp relay? thanx
Old Mar 25, 2009 | 10:29 AM
MeanYellowZ's Avatar
A standard 30 amp BOSCH square style relay works fine for one pump. It would wire as follows:
pin 30 - fused power in
pin 87 - output to pump
pin 85 - ground
pin 86 - + from ECM that turns on pump
Old Mar 26, 2009 | 06:24 AM
ssduane's Avatar
and remember, PCm will only send a three second 12v power until the engine is running.
Old Mar 26, 2009 | 09:02 AM
Which raises a question. In an accident, would this be safe? Guess it would depend on if the engine remained running or not. Just a thought.
Old Mar 26, 2009 | 11:49 AM
Andy1's Avatar
I've got the Walbro #GSL392, and the Walbro chart shows that it draws 13.9 AMPs. Why would you need a #10 wire?
"and remember, PCm will only send a three second 12v power until the engine is running." Once the engine is running, is there no longer 12V power to signal the relay? If this is indeed the case, does the relay need to be the latching type or how do you manage to keep the fuel pump running?
"Which raises a question. In an accident, would this be safe? "
This question keeps comming up in my mind as well. Many of the Cobra replica builders that run the Ford EFI, also install the Ford inertia switch that cuts the power to the fuel pump relay in case of an accident or roll-over. Do GM cars have some type of similar device?
Thank,
Andy1
Old Mar 26, 2009 | 12:16 PM
You don't really need a #10 gauge size wire. You could use a #14 gauge wire or a #12. Its just that its a bit of a long run & I prefer #10 wire. And planning for future pump(s) size upgrades does'nt hurt.
Old Mar 26, 2009 | 02:11 PM
brianjw4's Avatar
I wired mine up like MeanYellowZ and it works great. Mine does do the 2-3 second prime when I turn the ignition on and then shuts off.
Old May 29, 2009 | 02:57 PM
adam`'s Avatar
what all does the power output fromt he PCM do? im redoing my fuelpump wiring as i wired in my inertia switch and CCRM frm my 94 mustang and i keep having fuel pump connectivity problems. im sure its my CCRM but i plan to wire it straight to an ignition source in my trunk. when my key is on....i want my fuel pump on. i personally dont feel the PCM does anything as far as read outputs for tuning or anything fancy. isnt it strickly just an on offf switch for the pump? the whole idea is not to run a wire from the rear all the way to the bay.
thanks, adam
Old May 29, 2009 | 03:09 PM
eric1h's Avatar
So anyone wire it up with using the PCM? I have a carb setup, the pump says i can just run power and ground and not use a relay. What benefit would the relay give?
Old May 29, 2009 | 04:48 PM
RHDV8's Avatar
The PCM can't give the required current to power a pump, just a relay coil which uses considerably less current. So you use the PCM to energise the relay coil which in turn connects the battery (= lots of current) to the pump via the relay contacts.
Old May 29, 2009 | 05:58 PM
ls1nova71's Avatar
The benefit of the relay is it takes the load off of your ignition switch, if you have it wired up to come on whenever the key is on. The iginition switch isn't designed to handle the kind of amps an electric fuel pump pulls.
Old May 29, 2009 | 06:01 PM
crainholio's Avatar
In a wreck, the PCM will stop supplying pull voltage to the fuel pump relay, stopping the pump from running.
Hard-wire your fuel pump to a manual switch, and Darwin may have a chat with you later on.
Old May 29, 2009 | 06:22 PM
adam`'s Avatar
can anyone verify this? this was my question about wiring up the pump straight to an ignition source. fbodys dont have an inertia switch or anything that i would see killing the pump. how does the pcm know the car was in an accident? also, you have to remember most cars making serious power go with a stand alone which doesnt have any type of fuel cutoff for accidents.
Old May 29, 2009 | 07:19 PM
Pop N Wood's Avatar
I have a carb, but used a relay and an oil pressure cut off switch. The relay lets me run thinner wire to the oil pressure switch. And like someone said takes the load off the ignition switch. I have it fused right off the main circuit.
My 140 gph pump has a 7.5 amp fuse. 10 guage wire won't hurt anything but it is massive overkill.
Old May 29, 2009 | 07:32 PM
crainholio's Avatar
There aren't many really hard hits you can put on a vehicle that won't stop the engine. PCM sees the engine not turning, it stops the fuel pump.
Sure there are some wrecks that will leave the engine turning, but if the fuel supply line is severed guess what...the engine stops. See above.
Rig the fuel pump on a manual switch, and even with the engine stopped and a fuel line ruptured you'll still be spraying gas as long as the battery and FP circuit are intact.
They also have fire suppression systems. Don't look at what teenagers and 20-somethings are driving, look at what the guys with a few gray hairs run. There's a reason they're still alive and driving.
Old May 29, 2009 | 09:05 PM
eric1h's Avatar
What relay and switch did you use?
Old Aug 5, 2009 | 11:23 PM
1936 LS1's Avatar
Does this eliminate the need for "Hotwire" kits you see for cars that were EFI from the factory (F-bodies, Turbo Buicks, etc)? I know the factory wiring was marginal and the "Hotwire" kits were the way to ensure a full 13.2v (IIRC) to the pump.
