04 truck wire harness
Old Mar 22, 2009 | 11:48 AM
crazygn's Avatar
Default 04 truck wire harness
What would it take to make a 04 truck wire harness work in my mustang. I can maybe get one cheap and do some changes to it. Also would i need to run an 04 computer and would it be able to be tuned the same as say a 2000-02 computer
Old Mar 22, 2009 | 01:49 PM
Chris10an's Avatar
The 03 and up wiring is for the electric throttle. 01 and 02 have cable throttle. The 02 ecu wil fit, but not work on a electric throtle wiring.
You can use the 04 wiring and the electric throtle and the ecu on every ls,lm,lq etc based engine.
i would gues for about 500 usd you get a ecu, and your wiring fixed up.
chris.
Old Mar 22, 2009 | 03:52 PM
chevellepowered's Avatar
i got a 04 pcm, and a dbw tb.. if it helps..
