problems with MSD 6010- possible crank pulse issue?
Old Mar 27, 2009 | 09:57 PM
S10xGN's Avatar
Originally Posted by TJ
i played with mine anywhere from 0-20. it actually starts up quicker now. i have 22 in it. all dependant on the motor combo too.....
Is that initial or total? Sounds a bit strange to have 22° right off cranking speed, but I'm pretty open minded at this stage (just learning).
Russ
Old Mar 28, 2009 | 10:36 AM
TJ's Avatar
TJ
Russ
22 cranking.
it is a big duration camshaft.
my stock 6.0 liked more initial as well, but it had a fairly large cam for a stock cube. 237 duration.
i have 22 cranking, then it slowly ramps up to 34 in the midrange, back down to 32 up top. made 11 dyno pulls yesterday, and 32 degrees of total made 9 more hp and 10 more ft pounds than 30 degrees did.
my old 6.0 thats in a buddys car picked up 12hp from taking his timing from 36 down to 33 total.
plugs look good. air fuel is a lil rich still at 12.5. i want to get it to the track and lean it out a bit and see what et it runs. it might like less timing being leaner, but you can only do so much on the dyno. i want to see real results.
Old Mar 30, 2009 | 04:39 AM
chris-m's Avatar
mine is a 220/220 cam and so it usually sits at around 18 deg cranking and used to start ok at that. soon as its idling its around 33degress (vacuum advance included at +10) and once the throttle is opened up or the car is showing little or no vacuum the maximum timing is around 29degrees all in.(uk 95 octane fuel)
