flex plate info
Old Mar 25, 2009 | 12:21 PM
H8TO WRK's Avatar
Default flex plate info
OK I have a LS6 and a 4l60E I know for sure I have the wrong flex plate. mine has the 6 bolt pattern and has a spacer. I think it was from a 4L80 trans.
What I need to know is there different flex plates for different application? I need to order one ASAP so I cam move forward with my swap.
Old Mar 26, 2009 | 01:28 AM
G-Body's Avatar
sawzall wielding director
According to the GM LS1 swap book the flexplate you need is PN 12563136 and bolts PN 12553332 and was used on the f-bodies (98-02) and the 4l60e c/k trucks
Old Mar 26, 2009 | 06:56 AM
forcd ind's Avatar
if the flywheel is flat, and had a spacer between the crank/flywheel, it was for a 4l80e-all you need to do is rem both and use a flywheel for an LS1/LS6 and new bolts
