PCM controlled fuel pump relay - Issues
For whatever reason, the PCM control output for the pump relay is coming out as a ground. I have few sets of pin-outs and they all show plug C2, pin A7, Dark Green/White as the PCM output for primary fuel pump. I always understood this to be 12v for fuel pump, as opposed to ground for fans, etc....or are the truck harnesses different?
I'm using a 2003 LQ9 motor, harness, and computer. Fuel pump is a Walbro 255 in tank setup.
Any ideas?
Thanks
Do you have access to a scanner ?
I would make sure the ground are good to the back of the heads, frame, battery and body.. that the PCM grounds are good. Are you sure the ign 12+v lead doesn shut down as you crank ?
Let us know what you find..
are you able to crank it over, getting oil and fuel pressure ?..
Stay tuned
John
