6.0 swap.
Old Apr 6, 2009 | 02:37 PM
BlackTA96's Avatar
Default 6.0 swap.
Is a lq4/9 a direct swap into a ls1 f-body?
sorry if this has been beat to death but search is junk.
Old Apr 6, 2009 | 03:08 PM
NemeSS's Avatar
will need to swap pulley, acc, and oil pan with windage tray and pickup tube.
bolts right in.
Old Apr 6, 2009 | 04:16 PM
BlackTA96's Avatar
sweet. so no reluctor differences or wiring differences...right???
Old Apr 6, 2009 | 04:21 PM
ryanvv355's Avatar
The fuel injector connections are different and depending on what year LQ motor you get the MAF/IAT could be differnet. You can fix the injector issue by just swapping over your LS intake with injectors. 01 and later trucks have an intergrated MAF/IAT sensor with one five wire conection. If you retain the stock F-bod intake ducting with MAF and IAT you will be fine. I assume you are talking about swapping into your 98 F-bod? If so swap the 3 wire temp sensor over to the LQ motor as well.
Old Apr 6, 2009 | 04:40 PM
BlackTA96's Avatar
yup
it's going into the 98.
i have a complete donor ls1, so intake and everything will be coming off of the ls1.
sweet.
sounds like its gonna be pretty easy
Old Apr 6, 2009 | 06:03 PM
the_merv's Avatar
Veteran: Air Force
You will have to Drill & Tap a hole for the upper Alternator Bolt aswell.
