help with cooling problem
Old Apr 6, 2009 | 05:32 PM
JeaneGrae's Avatar
Default help with cooling problem
My buddy swapped in a lq4 drivetrain into a 79 full size pu. Everything works fine and the pullies are set identical to his 05 silverado with the same drivetrain, but the coolant isn't circulating. The t-stat is opening and is brand new. What could be causing the overheating? the only code his computer throws is the one for overheating, no other codes.
Old Apr 6, 2009 | 09:01 PM
bczee's Avatar
Could be a air pocket in the system, take step to purge the air out of the system.
Fill the system from the top radiator hose (disconnect it from the radiator) and then reconnect the hose and then top off.
Hold the engine at about 2000-2500 for a 20-30 sec to purge the system of air. Top off again and repeat a few times to get all of the air out.
Are you sure the T-stat is not binding in the housing and that it is opening at the right temp and that the fans come on at the correct time if your using electrical fans.
Old Apr 6, 2009 | 09:11 PM
forcd ind's Avatar
like bczee said, try filling from the top hose-filling the rad doesnt put water in the block because the thermostat is closed, needs water behind it to get hot and open it, then you can fill it up thru the radiator
Old Apr 7, 2009 | 05:32 AM
Pop N Wood's Avatar
Unbolt and remove one of the steam vent caps on the front top of the engine as you fill it. That gets the air out.
Also are you sure it is overheating and not just a bad sensor/shorted sensing wire? Did you check it with a second sensor or observe other signs of overheating beside the code?
Lasst thing, are the heater hoses hooked up? I hve heard LS motors circulate water through the heater loop while T stat is closed. Make sure there is a path their.
Old Apr 9, 2009 | 07:20 PM
98Camarod's Avatar
Then why would the temp gauge go up and show the reading of the higher temp? Just from the combustion?
From this post, I'm guessing that the coolant is circulated inside the block, and then through the bottom hose when the tstat opens and then pushes the cool water through the top hose and repeats the process?
Old Apr 10, 2009 | 07:28 PM
RE AND CHERYL's Avatar
I had the exact same thing happen in a 97 blazer last week. Turned out it had a large air pocket in it that only worked it's self loose when the engine warmed up. Real wierd because the truck sat allnight after we put it together adn in the morning it looked full. We ended up putting almost another gallon in that "full"radiator.
Re'
Old Apr 11, 2009 | 06:35 AM
topher455's Avatar
Sounds like an air pocket to me also. Like the others said fill the motor through the upper rad hose with the steam vent unhooked.
