Ls1 in 1998 blazer 4x4
If you are going thru all the work of taking the 4wd out, I'd suggest removing the torsion bar susp. and replacing the shocks with QA1 coilovers, again assuming that you are building a street truck rather than a mud runner (no 4wd)!
Mounts should be the same however, any other part you'd need to be 4wd.
As far as utilizing the T56, it can be done, just depends on how deep your pockets are!!
when the diff is removed, you will have to make a x-member out of box to suit whichever pan you use.
As far as the t56 is concerned, you'll need the complete pedal assembly either from a M/T S-10 or from the car that you take the tranny out of. With the s-10, at least the older ones, camaro pedals can be adapted to work. You need to run the MC from a t56 car and adapt it to the firewall. It can/has been done but it depends on how much work you really want to do!
I suggest going to s10forum dot com and reading up on the LSx swap page.
Good luck.
Good luck.
Make absolutely certain that you have something (outer halfshaft stubs, big bolts, whatever) holding the front hubs together. Without something there, they WILL come apart.
I think the rest of these guys have answered your other questions. Might want to think seriously about a coilover conversion to eliminate the torsion bars.
Also, if you're looking for the slammed look in a 4wd chassis, you'll be begging for trouble. The ball joints aren't set up properly to get down that far and you'll be replacing them regularly.
'JustDreamin'
