Need some help identifying these conncetors...
Old Jun 2, 2009 | 12:33 PM
  #41
pjtimmer's Avatar
You're welcome.
Don't bother to look into hooking it to older cars fuse box. If I look at most aftermarket ls2 harnesses, most of them have universial fuse boxes. In the end I just need about 6 fuses and 4 relays... isn't it?
If you can answer the questions in my last exel sheet , I will be one step closer.
Please take in consideration that I probably need some MYC wires that are not there in my old MM6 harness. Like Park/Neutral signal C1#1. I have no idea what I miss.
Thanks
Peter
Old Jun 2, 2009 | 12:41 PM
  #42
CalEditor's Avatar
Yes I should fined some time tonight.
Wait until you see what the inside of the OEM fuse box looks like. I will post a picture.
Ummmmm I just looked and I don't have any here they are at my other house in Charlotte Maybe I have one left at work.
To replicate this will take some work.
Old Jun 2, 2009 | 01:07 PM
  #43
pjtimmer's Avatar
Would it be intersting to buy th DIY kit form currentperformance http://www.currentperformance.com/Ac...iring_acc.html
Peter
Old Jun 2, 2009 | 07:53 PM
  #44
CalEditor's Avatar
Wow they are racking in the cash.
I guess they don't need to sell very much per day to make a living.
Old Jun 3, 2009 | 01:23 AM
  #45
pjtimmer's Avatar
You're right.
I emailed cleveland pick-a-part also for that fuse box. Havn't heard jet.
Gues I also need those gray connector blocks... do you where I can get new pins that go into the gray blocks? and new pins for the ECM connectors?
thanks
Peter
Old Jun 3, 2009 | 07:04 AM
  #46
CalEditor's Avatar
Ouch. I take that as you chopped them off?
Maybe plan B is your only option.
Let me print the fuse box flow out today and really look it over . You are going to have a lot I mean a lot of splices.
Just on the Power-Train Ignition #1 Circuit (not everything on IGN #1) you will have possibly 6 splices coming out of the IGN #1 relay going to 5 fuses and 7 more splices. That will be 13 splices off of 1 relay and I am not including all of the fuses because they are single wire connections.
I think I may have missed some
I see 9 wire coming off fuse #12
Old Jun 3, 2009 | 12:13 PM
  #47
pjtimmer's Avatar
Yep, ouch... Time for plan B.
I might be able to add a distribution block to the Ign relay, so it would be easier to splice/ distribute all those wires.
I am not to worried about this part, as long as I know what to do with all the wires in my exel sheet...
Thanks
Peter
Old Jun 3, 2009 | 12:39 PM
  #48
CalEditor's Avatar
Peter this is complicated on my end. looking over the Schematics that have both auto and man transmissions in them is making it more difficult.
I beleave I sorted through it and will post a bunch of pictures that I will make up.
Old Jun 3, 2009 | 12:46 PM
  #49
pjtimmer's Avatar
Thanks, that would be great!
Old Jun 3, 2009 | 01:02 PM
  #50
CalEditor's Avatar
This is the simplest one (I think)
This is the Fuel Pump Circuits
The ECM turns on the Relay from Connector #1 terminal #50. This D-GM/WHT wire should be in the Fuse Box Connector #2 Terminal B6 and it need to go to the control side of the relay
The Ground wire that is located in the Fuse Box Connector #1 Terminal C10 can be used or just hook up a ground to the other side of the Control side of the relay
Battery feed to the relay should have a 20 amp fuse
The Fuel Pump Feed wire is in the Fuse Box Connector #2 Terminal A6. This wire is grey and goes to the Pump it is on the other side from the B+
I hope I did that correctly.
Old Jun 3, 2009 | 02:24 PM
  #51
pjtimmer's Avatar
Oké, if I understand you correctly... translated to a standard bosch relay, see below.
Correct?
Peter
Old Jun 3, 2009 | 07:14 PM
  #52
CalEditor's Avatar
87 & 30 are the contacts correct.
They are labeled the same on the Siemens Relays we use.
Old Jun 3, 2009 | 07:30 PM
  #53
CalEditor's Avatar
Charging
Old Jun 3, 2009 | 09:44 PM
  #54
Marktainium's Avatar
I'm using a 07 vette setup as well, what do i do about this fuel level sensor wire? and what was the verdict on the 2 stage cooling fans?
Originally Posted by CalEditor
The Fuel Level Sensor MUST be hooked up to the PCM.
If you don't do this it will hurt performance
Old Jun 4, 2009 | 10:04 AM
  #55
pjtimmer's Avatar
Charging
As far as I know, originally the camaro has a fuse and wire for this. It's a permanent powered red wire. If possible I would like to use this stock provision for that.
Peter
Old Jun 4, 2009 | 10:47 PM
  #56
CalEditor's Avatar
Peter I was very busy today. I got some new toys hooked up in a customers/friends car today. I am 1/2 way home on hooking up evrything. I have another data loger on top of this one to install. This one is not run through the ECM. This one has it's own set of sensors.
I am on the wrong TPS circuit. I am on the 5V closed and 0V WOT, but it doesn't look good for a $7000 dyno tune.
Old Jun 5, 2009 | 03:13 AM
  #57
pjtimmer's Avatar
Looking nice, that datalogger.
That somethng I am not thinking about right now first te make te car work.
Peter
Old Jun 5, 2009 | 04:47 AM
  #58
CalEditor's Avatar
I will start on the next Schematic right now.
Old Jun 5, 2009 | 04:55 AM
  #59
pjtimmer's Avatar
Thanks
Old Jun 5, 2009 | 05:49 AM
  #60
CalEditor's Avatar
Peter
I don't think so. This is a much smaller wire and you should have it in the harness.
Hey is the ECM marked E40?
