LS1 swap question
Old Apr 22, 2009 | 07:03 PM
DRIVER456's Avatar
Default LS1 swap question
Is a 5.7 LS1 short block out of a 97 C5 Corvette the same block thats in a 99-02 Chevy Silverado PU truck(4.8-5.3).Will the parts interchange from the PU motor to the LS1 short block.Not the heads,I have my own heads.But water pump,front & rear cover's etc................Paul
Old Apr 22, 2009 | 07:57 PM
poweredbychevy's Avatar
yes they will interchange
Old Apr 22, 2009 | 08:45 PM
71 chevelle's Avatar
X2 What he said.
Old Apr 23, 2009 | 04:11 PM
DRIVER456's Avatar
Thanks
Old Apr 23, 2009 | 04:16 PM
andrew69_04's Avatar
only thing that is diff is the accessory drive. truck and vette accessories sit diff distances off the block. you cannot innerchange them.
Old Apr 23, 2009 | 05:24 PM
DRIVER456's Avatar
I just want to use my LS1 short block & heads that I took out of my C5.What I want to do is by a used 99-02 Chevy silverado pickup with alot of miles and pull that motor out and put my 5.7 shortblock in and use all the truck stuff back in. Will have a problem?Are the the bolt holes different on a 4.8/5.3 motor then the 5.7.....................Paul
Old Apr 23, 2009 | 07:36 PM
no you are good to go.
