Automatic trans clearance in first gen F
Old May 3, 2009 | 10:41 PM
Wasson's Avatar
Default Automatic trans clearance in first gen F
I am in process of installing a 2004 LS1 (GTO) motor and auto tranny into a 69 Firebird. I used the TCI front subframe kit, which went together well and bolted right on.
Can someone who has done the LS and automatic into a first gen F body let me know if they has issues with the tranny hitting the floor/tunnel? If so, any specific advice?
Thanks.
Old May 4, 2009 | 07:20 AM
rsz288's Avatar
Thanks.
4L65E fitted ok but was tight. Then I changed to a 6L90. That needed some clearancing at the top of the tunnel, and a little at the rear. Its tall.
4L65E actually wider at the pan than the 6L90.
Old May 4, 2009 | 07:30 AM
69LT1Bird's Avatar
I had to massage the floor so the servo would not hit, it depends on the mods. 4L60e here.
Other than that, no issues.
