Corvette regulator filter question
Old May 5, 2009 | 03:14 PM
Indyjc's Avatar
Default Corvette regulator filter question
Did a search and can't find the answer I'm looking for. The Corvette regulator filter regulates the fuel pressure at 59 psi. is this correct ? Thanks
Old May 5, 2009 | 03:31 PM
kirtondog23's Avatar
In Theory 58 psi although many things can affect this. mine runs at 55 -56 at idle and closer to 60 at WOT
Old May 6, 2009 | 11:31 PM
thunderstruck507's Avatar
mine showed 56-58 at the rail
Old May 10, 2009 | 09:08 PM
Valve-Floater's Avatar
Can you pull from the filter/reg? Like haveing the filter before the pump?
Old May 10, 2009 | 11:02 PM
poweredbychevy's Avatar
No has to be before it
Old May 11, 2009 | 11:12 AM
Project GatTagO's Avatar
Fuel pressure should not fluctuate.
Andrew
