DBW startup problem
Old May 25, 2009 | 03:21 PM
fast400's Avatar
Crainholio,
I'm with you! Once I get it running with charge, I'll post if the problem persists.
Bob
Old Jun 28, 2009 | 03:31 PM
fast400's Avatar
Update...Problem solved.
On the 2006 setup, apparently if the PCM detects no charging, then the pedal won't work. I hooked up the radiator, put the belt on and voila' the pedal started working just fine.
Old Jun 29, 2009 | 09:35 AM
mramay's Avatar
Originally Posted by DarthMonte
Verify you have the right TAC module and pedal for your PCM. Street & Performance has a listing of the TAC modules part #'s and their corresponding years. Or Speartech can probably tell you if you have the correct setup.
I had the same problem when I put my 5.3 in, and it was because I had the wrong TAC module and cable.
Tried to find the S&P list and wasn't successful. Could you provide a link??
Is this the right S&P? http://www.hotrodlane.cc/
John Spears is going to build my wiring harness (when I get the $) but I'd like to get the correct parts first.
Thanks,
Mike R.
Old Jun 29, 2009 | 03:55 PM
fast400's Avatar
That's the right address. You have to go through their catalog....painful as it's not easy to navigate.
