C5 t56
Can the trans be used without the vette rear end?
I have plent of space seeing as this might be going into my 64 c10 pick up. Just want to get more weight to the back. Any ideas on this. Also all the vette t56's around here are about a 1000 vs. the fbody t56 going for 1500-2000
So in theory I would have a LS with a vette trans/torque tube hooked to a gm 12bolt.
Can a torque tube be made to bolt to an f-body t56 with little trouble? the "bellhousings" look a bit different between the two transmissions. Also what is that rod sticking out above the input shaft on the vette trans?
Sorry for all the Q's just trying to think outside the box a little.
The vette t56 is designed to be rigidly mounted in the chassis, at the rear of the vehicle. So, you've got to do IRS, there's no good way to run a 12 bolt, unless you convert it to IRS (haven't seen that done).
'JustDreamin'
Re'
May seem like more work then benefit to move the trans further back on this app but I think it would be pretty cool and I have no problem doing the work.
Re'
