Need help wiring in ECU
Old May 16, 2009 | 01:05 AM
brianfromhawaii's Avatar
Default Need help wiring in ECU
I am modding my own harness and need some tips, based off of http://chevythunder.com/1999-2002%20...%20pinouts.htm
Which wire needs to be constantly +, which wire needs to be ignition +, why are there so many grounds?
Old May 16, 2009 | 05:01 AM
Jones'n's Avatar
4 grounds is a lot? Pin 1 and 40 on each connector is ground (Like the pinout says)
20 and 57 are constant + (Like the pinout says "Battery Positive Voltage")
19 is Ignition + (Again, just like the pinout says)
Old May 16, 2009 | 11:40 AM
4 grounds for one device is a lot. is it a failsafe or something?
Old May 16, 2009 | 03:42 PM
LS1MCSS's Avatar
If it's a 99-02 harness, there should only be three ground wires that bolt to the back of the head. PM me your email and I'll send you the engine harness schematics.
Old May 16, 2009 | 11:20 PM
pm sent
