Fan wiring questions
Old May 20, 2009 | 10:42 PM
LS1 TJ's Avatar
Default Fan wiring questions
I'm getting close to firing up the Jeep TJ LS6 project.
Just a quick question in regards to fan wiring. I'm using a Spal fan with a Painless relay kit.
Any negatives (no pun intended) to connecting the high amp wire on the relay to the back of the alternator? Makes for an easier way to wire the fan relay.
Thanks
Old May 20, 2009 | 10:45 PM
sandking's Avatar
I dont see any problems, after all, the alt is your main source of power.
Old May 21, 2009 | 01:02 AM
bczee's Avatar
Could cause Radio IF.... I would suggest using the Battery as it will help filter the IF out and also act as a buffer from surges as the Alternator will do that.
