ls1 tacoma shifting problem
Old May 27, 2009 | 04:12 PM
Absolutezero's Avatar
Default ls1 tacoma shifting problem
I have a 96 taco with an 04 gto ls1 with a 4l60e (gto)to a np241 tcase.I used the stock gm vss on the t case and it wont shift 2nd -3rd with out lifting off the gas .we have tried using hp tuners to make it work but still haveing problems do I need to move the vss to before the tcase? has someone else had this problem and fixed it?
Old May 27, 2009 | 05:26 PM
CalEditor's Avatar
What is the OSID?
Is it for the GTO or a Truck?
Is the OSID #12587604C and the PCM# 12586242
Old May 28, 2009 | 09:20 AM
the ecu is from a 04 gto where do I find the osid #
Old May 29, 2009 | 09:19 AM
any help?is there a way to bypass the trans ecu all togethor and manualy shift it
