ac low pressure wire
Old Jun 20, 2009 | 03:46 PM
fast400's Avatar
Default ac low pressure wire
Does anyone know what to do with the blue cable on the low pressure switch??
I plan on letting the ecm control things, but the low pressure switch doesn't have a place at the ecm. (2006 silverado ecm/harness). I have the high pressure switch going to the pcm which is ok.
I plan on running the clutch power through my original a/c switch...sound right?
I'm using the original vacuum can set-up with the original evaporator, updated poa valve (134), hot rod air condensor...am I missing something (other than the drier).??
Old Jun 23, 2009 | 03:43 PM
fast400's Avatar
nobody??
Old Jun 23, 2009 | 05:23 PM
bczee's Avatar
Since I don't have the Gen III/IV AC system, I would suggest you try finding a FSM to follow the wiring diagram. Or find someone with Alldata access.
