Coolant Line to Tb
The issue I am listing here is one I came across the other day that I didn't have knowledge of beforehand:
Here is my issue: somewhere along the way the coolant line to my throttle body (passenger's side) was removed (not bypassed to driver's side like it should have been if done properly) and the coolant inlet (pass side) was capped with a rubber round cap.
The driver's side of the throttle body is still connected to the coolant air bleed line (like it should be stock) so to me it looks like half of the job of a throttle body coolant bypass has been done.
The cap burst the other day shooting coolant under my hood, and I have since replaced the cap and its holding. But, I need to figure out where the coolant supply line came from on the radiator and get it rerouted back to the tb so I can either put it back to stock or bypass.
What do yall think? The radiator is a koyo by the way.
Thanks for any help you can offer.
There isn't a coolant line even present...
Pat
The only problem is, I don't know for sure where you want to put it in the cooling system. This might help though:
http://www.midwayautosupply.com/pc-1...-34-47112.aspx
I think guys use fittings like this to plumb it back into the large coolant hose that goes to the radiator, but I am not 100% sure. A fitting like this might be a good start though.
Are you planning on keeping the TB inline of the head steam vent or going to bypass the TB ?.. either way, it need to be connected to the pressure side.
Pat
Jack
I have also seen someone drill and tap the front of the pump housing.
Pat
Runs great! Thanks for answering the questions and to miro for putting up with all of mine!
Pics
http://picasaweb.google.com/Andrew67...62171100875810
http://picasaweb.google.com/Andrew67...62176972263698
http://picasaweb.google.com/Andrew67...62183108671042
Pat
