fuel system question
Old Jun 24, 2009 | 03:24 PM
camaross82's Avatar
Default fuel system question
Does any body know what adaptors fit the spectra fuel tank from rock auto parts? I purchased the 69 camaro FI tank with the in tank pump. I am about to order the fuel lines and I dont know what fittings I need for the supply or return lines. I was going to run braided line with an fittings.
Old Jun 30, 2009 | 09:37 AM
jman32779's Avatar
Default Same problem!!!!!
I went to Ace hardware and bought a 3/8 inverted flare female union. then I got a 3/8 to npt adapter. Once you adapt to npt you can adapt to an and you are good to go. I struggled with this crap for weeks and still am waiting to hear back from North coast muscle as to what fittings I need. Nobody has been even remotely helpful. The Fitting size is 3/8ths So you need a 3/8ths female 45 degree inverted flare to 3/8ths npt fitting. If you need any other help you can call me after 5 eastern time at (407) 353-3249. I am going through the exact same thing. My name is Justin
Old Jun 30, 2009 | 10:11 AM
TomM's Avatar
Do you have a picture perhaps? Do you have fittings in the tank already, or just straight pipe? Several companies make them, Russell, Aeromotive etc.....put up a picture or a link to the tank so we can get you going...
T,
Old Jun 30, 2009 | 03:18 PM
bczee's Avatar
I might suggest looking into coverting it to AN fittings.. Just a bit more secure and many of the manufactor have adapter of all type... compression to AN, flares to AN, QD to AN..etc.. But the hardware 45 deg flare are a less costly way.
