Another LS1 240Sx
a.russell.nyc at G mail .com
Check out Miro's build thread he just did the swap over last winter.
Also, you might want to make a solid decison on your rear end plans before you buy the driveshaft. Unless you happened to pick up a Hicas model you have a open diff in your 92. You can stick with that if you like, but there are many other options out there that can get you LSD. For my LS conversion, I went with the 94 q45 3.54 diff and it has a slightly longer snought than the stock Diff. Pick your diff first and you won't have to buy 2 driveshafts.
