Question for the G-body owners
Old Jul 12, 2009 | 11:34 PM
eric305tpi's Avatar
Default Question for the G-body owners
Question for all of y'all that have done the swap allready, where have y'all been putting the PCM at? I've got a wrecked donor LS1 camaro that I'm gonna be using the harness out of after reworking it and removing the items that wont be used. I've looked around some but really havent seen much talk on the PCM locations. This is gonna be in a 85 GN. I'm gonna be planning on using BRP's conversion items for the swap including the LH8 oil pan setup (does this pan have an oil level switch in it like some of the other pans do? havent even looked to see if the stock 98 f-body pan does).
Old Jul 12, 2009 | 11:52 PM
G-Body's Avatar
sawzall wielding director
I put my PCM on the top of the inner drivers finderwell but that is because the truck harness is the right length for there. John B put his on the pass side because the f-body harness locates it there. he had to move the coolant overflow bottle to do that.
