Fuel fittings
Old Jul 13, 2009 | 05:44 AM
camaross82's Avatar
Default Fuel fittings
I am doing some shopping for fuel system fittings. I am having trouble finding a fitting to go from 10AN to the stock LS1 fuel rail. I have found the quick connect fittings for LT motors on jegs, are they the same ones needed on the LS motors?
Thanks
Dallas
Old Jul 13, 2009 | 07:18 AM
John McGraw's Avatar
Russell has the fitting in their catalog, but not in 10AN. Are you sure you need a 10AN fitting? that is a huge fitting for a fuel line! I have never seen anyone use bigger than 6AN.
Regards, John McGraw
Old Jul 25, 2009 | 10:00 PM
camaross82's Avatar
not sure. the PSR i was looking at had a 10 an outlet.
Old Jul 26, 2009 | 12:17 AM
bczee's Avatar
Russell and other Quick Disconnect fitting are only designed for OEM systems and that limits you to AN -6 for 3/8" or 5/16".. so.. that would be the bottle neck in the system... AN -10 necking down to -6 aft the fuel rail.. you many as well do the whole system over from fuel rail to pickup/sender if you really need anything bigger than -6 (-8 or -10).
what is the estimated HP that you are looking to produce ?
