Bad Corvette Filter??
My fuel pressure is odd...sometimes 55lbs, sometimes 50lbs at ignition on. When running it drops to 40 sometimes, sometimes 50lbs.
After turning the car off it will hold pressure for all of about 10 minutes before slowly going down.
Some facts for ya: Ricks Tank with new pump. Double checked and cleaned injectors (only 400miles of use on engine/inj). Pulled fuel rail, turned on ign and watched for dribble at any injectors...nothing? The Corvette Filter is new...and the only thing I can't actually test. Does it sound typical for a bad one???
For the fuel pump... What are you using as a power source ?... what gauge wiring ?... Also check the ground is a good one.
