Help with Gauges!!
Old Jul 13, 2009 | 09:18 PM
cainsw's Avatar
Default Help with Gauges!!
I have a 98 TA racecar that is getting a carbed LS setup and I need to know what I have to do to put a mechanical oil psi and temp gauge in one? Reason for the mech. gauges is because it has no factory harness or PCM. Do I need anything special.
Old Jul 13, 2009 | 11:21 PM
Cam72aro's Avatar
There is an adapter that is sold that goes in place of the oil pressure sending unit. For the temp sensor I removed the allen plug at the rear of the head and drilled and tapped the hole to the corrrect adapter fitting. This is also sold in an adapter kit. Do a search on here, as I dont have the part number in front of me. Josh
