Have a couple ?'s
Old Nov 18, 2003 | 08:13 PM
L-EATER's Avatar
11 Second Truck Club
Question Have a couple ?'s
I am about to begin swapping a Whipple charged 5.3/4l60E into my 94 work truck. I have almost all the parts rounded up and I am currently working on the harness. I have a couple questions for you guys. My pinouts show pins 58 and 59 on the pcm blue conn to be "class 2 serial data" A green wire and a yellow wire. Which one do I hook to the DLC?
Question #2 What are you guys using to hook fuel lines to the fuel rails? Does someone make a click on fitting that converts to AN or is there another way?
I am planning on putting the 94 temperature sending unit in a "T" in one of the heater hoses and using it to control the stock gauge. Does that sound OK?
I can't wait to get started
Old Nov 18, 2003 | 08:32 PM
Keith's Avatar
I can answer #2:
A while back i asked about the dsame thing for my dad's conversion. One guy used a swagelok fitting, while the other used a 3/8" hard line to -6AN adapter. Hope that helps.
Old Nov 18, 2003 | 11:55 PM
Project GatTagO's Avatar
http://www.performanceplumbing.com/
Pure Choice make an littla adapter that clips on to the fuel rail and converts it to AN-6 line.
Andrew
Old Nov 19, 2003 | 02:53 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
58 is the serial data line to the diagnostic connector.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Nov 19, 2003 | 06:21 PM
Lesrace82's Avatar
I used the 3/8" hard line adapter to -6an its worked great and havent had a problem with it.
Its made by Russel and you can get it through Jegs or Summit.
Old Nov 19, 2003 | 06:55 PM
L-EATER's Avatar
Ok, thanks guys. I am gonna finish the harness Friday. Thanks for the link to the AN adapters-that is exactly what I was asking for.
