Heated O2's
Old Jul 31, 2009 | 11:54 PM
strtlegal's Avatar
Default Heated O2's
So got everything wired up, all the pinks to key hot and orange to battery hot. But I noticed while under the car and keys out of the ignition my O2's are heating up. Is this the pcm's doing? Did I some how give a certain pink wire a consistant hot fead thats allowing this?
Is this normal? lol
I would think this would drain the battery if its always heating up?
Your help as usual is appreciated!
Old Aug 1, 2009 | 04:44 AM
rsz288's Avatar
Is this normal? lol
Should be no power to O2 heaters unless ignition is in run position.
Old Aug 1, 2009 | 10:28 PM
strtlegal's Avatar
Thats what I figured, so I re-checked the wiring to the fuse block and I wired it off of a constant hot...dought..
Shes all fine now!
Thanks
Old Aug 2, 2009 | 12:47 AM
V8Rumble's Avatar
Glad I'm not the only one that does that kind of stuff...
Old Aug 2, 2009 | 01:16 AM
strtlegal's Avatar
Lol I was thinking well maybe the computer was learning new perameters after the new flash..lol
I knew all my pinks and oranges were wired correctly so I was thinking that it was a deeper problem or wiring ahead of the computer...easy fix!
But stay tuned there will be plenty more wtf's!!
thanks
