EVAP Solenoid
Old Aug 10, 2009 | 04:59 AM
Pete walsh's Avatar
Default EVAP Solenoid
Can some one explain how the EVap cannister etc works please?
This should be the last little problem sorted before the car goes for MOT.
Im after how the solenoid works.
Cheers
Old Aug 10, 2009 | 10:33 AM
cutlass_455's Avatar
It opens to pull fuel vapors into the motor and burn them. Its there to keep the hippies happy.
Old Aug 10, 2009 | 11:59 AM
bczee's Avatar
The PCM does control the EVAP Solenoid and Valve. The PCM needs input from the fuel take pressure and fuel level. Without those.. the PCM would never open the valve to purge the vapors out of the tank.
If you doing a non-Smog conversion, I would just do alway with it. I just run a Charcoal Canister and use the EVAP Port as a vacuum source for the can on my Chevelle.
If you doing a Certificed SMOG Conversion, You will need to get the sensors in the fuel tanks sender/pickup connected and wired as input to the PCM.
Old Aug 11, 2009 | 03:32 AM
Pete walsh's Avatar
So do I need fuel pressure or fuel tankpressure as wellas fuel level?
Does any one have any diagrams on how the system works?
Cheers
Old Aug 12, 2009 | 04:05 AM
Pete walsh's Avatar
Bumpage
Old Aug 12, 2009 | 04:53 AM
LS1MCSS's Avatar
Cheers
What year and car is your harness and pcm from?
Old Aug 12, 2009 | 07:40 AM
Pete walsh's Avatar
07 LS7 Corvette
Old Jul 27, 2010 | 09:43 PM
beddo's Avatar
Wink Speedy Pete, 72 nova ss
Pete, You would not be the speedy pete that had the 72 ss nova that was in hot rod magazine are you? In case you are what color blue was it? I got the nova now and looking to touch it up. Thanks.
yes or no? need to know if u read this, ty.
 Michael S. Palmer
Old Jul 6, 2016 | 01:27 PM
hahai1's Avatar
Hi Ty,
I am the Speedy Petey you are looking for. My son found this last night. Email me back and I can answer any question you might have. Look forward to talking to you soon
Speedy Petey
