ls1 into a 96 3.8 firebird
Old Aug 22, 2009 | 12:57 PM
1994z's Avatar
Default ls1 into a 96 3.8 firebird
i have a ls1 and a 99 harness and computer. i have downloaded the schematic for the 99 retrofit. question is will i be able to use my stock cluster as far as the oil pressure and water temp guages or will i have to use a 99 cluster. what sending units do i need to buy 98 or 99. thanks for any help yall can do for me.
Old Aug 22, 2009 | 11:28 PM
MasterMindMotorsport's Avatar
99+ sensors are a must with 99 harness and ECU
Old Aug 23, 2009 | 07:41 AM
1994z's Avatar
alright that is one step closer. thank you. anyone else swap a ls1 into a v-6 car?
Old Aug 23, 2009 | 11:46 AM
Cutlass3800's Avatar
This guy had a full parts car at his disposal, but he posted a lot of pictures and explained how his swap went. I bet he could answer some questions for you.
http://www.fullthrottlev6.com/forums...ad.php?t=56976
Now as a reward, you should send me the L32 powertrain you are planning to remove.
Old Aug 23, 2009 | 01:40 PM
the last 98+ V6 to LS1 swap we did in house left us wishing we had a full parts car to do the swap. I couldn't recommend having a donor car on hand any more.
Old Aug 23, 2009 | 03:53 PM
the_merv's Avatar
Veteran: Air Force
I used the Gauges in my 1995 and they work without a problem.
Here is my conversion thread...there is some wiring info in there..
https://ls1tech.com/forums/conversio...to-95-z28.html
