turbo turd s10
i used the 3/8 for the return line and used brass fittings for under bed connections . ran a 5/16 high pressure line out tank to line
started on feed lines to rails
engine bay getten washed off too
since i had only single exhaust i moved the trans cooler to d/s and added a fan
i made some cooler lines out 3/8 alum fuel line i had
i mounted the trans temp above trans with brass fittings. hint make sure you bring a ground wire to sender if you relocate it. ask me how i know
i made line for turbo -4 off sender
more photos will come tom and thursday
