Duramax Camaro
Old Sep 24, 2009 | 01:45 PM
  #41
the_merv's Avatar
Veteran: Air Force
Originally Posted by gnx7
I think a BBC all iron is in the neighborhood of 775lbs.
Holy ****..
Old Sep 24, 2009 | 02:35 PM
  #42
TurboBandit's Avatar
Originally Posted by the_merv
Holy ****..
WOW.... i had no idea~~~
But this buiild is rediculously cool
Old Sep 24, 2009 | 07:16 PM
  #43
topher455's Avatar
Yikes. 830lbs of diesel torque. I wonder how the car will handle though. Is it set back alot?
Old Sep 24, 2009 | 07:38 PM
  #44
JOHNBOY66's Avatar
It should handle it just fine.
Mike Wood's NX Mustang is also out of the same shop this car is being built in. It won the diesel class at Drag Week. If he would have entered in Small Block Power Adder which he could have. He would have placed second. Mike ran a best pass 9.717 @ 147.88 on an easy launch. We where messing with the tune up all week. It is really coming around.
The Z28 has all the potental Mike's Mustang does. Just takes time to get it all sorted out. The Z28 has a good deal more electronics to mess with and learn. The controls for the VGT turbos and the PCS trans controler to name a few things. The Mustang has non of these so the learning curve will be steeper but what we learn with the Mustang should help with the Z28.
Old Sep 25, 2009 | 01:00 AM
  #45
teblmb's Avatar
we need to see vids of that thing. its gotta be a beast.
Old Sep 26, 2009 | 09:33 AM
  #46
topher455's Avatar
Not saying it wouldnt just curious if there was any special considerations made for the extra weight over the front tires. BB springs?
Old Sep 26, 2009 | 10:33 AM
  #47
JOHNBOY66's Avatar
No different than the big block that was in it.
Old Sep 27, 2009 | 10:02 AM
  #48
topher455's Avatar
Gotcha!
Old Sep 27, 2009 | 11:08 AM
  #49
Parasoth's Avatar
http://www.team.net/sol/tech/engine.html References are at the bottom of the page.
Also..
"For one with an iron intake and heads, approximately 650 lbs. An aluminum intake will reduce that by about 20 lbs, and aluminum heads by about 70 lbs. "
No, it's not close to 1000 pounds.
Gosh.
EDIT:
So I was curious, grain of salt, http://www.shadetreemechanic.com/duramax_diesel.htm.
Old Sep 27, 2009 | 07:23 PM
  #50
JOHNBOY66's Avatar
Interesting. But the link to duramax weight was referencing the 7800 In line not the 6600 V8.
IIRC it weighs 765.
Old Sep 28, 2009 | 12:26 AM
  #51
Parasoth's Avatar
Thank god, I don't know too much about diesels and that was the only reference on a quick google search I could find. So I am guessing the 6600's are the truck engines, and 7800's mentioned would be like.. fu.. a dump truck or something? Or a big ol kenworth loll.
Diesel cars rock, nothing like making two different types of smoke at the same time.
Hmm, how many gears would you go through going down the line with that much HP? Shift points would be what, 3000 or so?
Old Sep 28, 2009 | 12:54 AM
  #52
59 camaro's Avatar
i had the same idea but not the money....lol good luck with this bad *** car
Old Sep 28, 2009 | 03:50 AM
  #53
LilJayV10's Avatar
At least the front end won't come up...
Stranoize it...it should be ok.
Sweet *** build.
Old Sep 28, 2009 | 07:39 PM
  #54
malibu795's Avatar
IIRC it weighs 765.
iirc thats dry weight..
i know the 01 dmax weighed ~900lb at so-cal diesel ... dont know if it was dry or not.. it was darn near fully dressed
as for tranny bolt up.. dmax come with GM standard bell housing bolt pattern.
then flexpat would need to be re-drilled for diff bolt pattern.
4L85E comes stock with the Duramax in the fullsize Cargo vans
