C6 Corvette Ignition Button?
Old Sep 19, 2009 | 04:14 PM
iansane's Avatar
Default C6 Corvette Ignition Button?
Has anyone adapted one of these to a standard ignition system without running a matching BCM? I've got a functional unit I picked up at work and was curious if it seemed possible to rig it to turn the car on/off/acc. I'm using an engine start button right now from an s2000 but I'd like to have one that runs all three on/off/acc. From SI;
Ignition Mode Switch
Code:
Pin               Wire Color         Circuit No.       Function
A                 L-BU/WH           5725              Ignition Mode Switch Mode Voltage Backup
B                 D-BU              5719              Ignition Mode Switch Start LED Signal
C                 BN/WH             230               Instrument Panel Lamp Dimming Control
D                 BK                1450              Ground
E                 L-GN/WH           5723              Ignition Mode Switch Mode Voltage
F                 L-GN              5724              Ignition Mode Switch Mode Control
G                 PK                5722              Ignition Mode Switch LED Supply Voltage
H                 OG                5721              Ignition Mode Switch Off LED Signal
J                 L-GN              5720              Ignition Mode Switch Accessory LED Signal
K                 L-BU              5726              Ignition Mode Switch Mode Control Backup
The LED stuff would be easy but how can I find out what the other stuff does and if it's possible?
