Orientation of Fuel Pump Relay
Old Sep 20, 2009 | 08:28 AM
Danno74Z's Avatar
Default Orientation of Fuel Pump Relay
Hello,
Fuse box from a 2000 Camaro
I have an odd request. Can a few people verify the orientation of the fuel pump relay in the fuse box. A while back I completely reworked the dual fuse boxes for my conversion and I might have put it back reversed. If you look at the fuses all the lettering is facing the same way except for the fuel pump relay. Perhaps I made a mistake when I reassemble it. I don't want to hook up the battery and roast something - probably kill the relay. I did review the schematics and I believe it is in correctly but I need a sanity check - THANKS!!
Danno74Z
Old Sep 20, 2009 | 06:26 PM
Danno74Z's Avatar
I got it figured out - had it reversed.
