Flywheel fitment question
Old Sep 20, 2009 | 04:01 PM
sgaynor5's Avatar
Exclamation Flywheel fitment question
Put the 5.3 into my 65 gmc c-10. Got flywheel/clutch set for an 02 silverado 4.8. Flywheel makes contact with the block and whe ring gear is to far forward for the starter to engage. Put flexplate that came off engine and flywheel on flat surface and there appears to be 3/8-1/2 inch difference. Thought that 4.8, 5.3, & 6.0 all had the same .4 inch recessed crank. Would flywheel from an 02 camaro 5.7 be offset that .4 inches? Checker offers a clutch seet for that application that is splined right for the stock sm420 tranny that will be going behind it.
