flywheel and balancer
Old Oct 1, 2009 | 07:47 AM
ak226's Avatar
Default flywheel and balancer
Hey guys,
I am collecting the rest of parts to put the ls1 in my chevelle and was not sure about a ring gear and balancer for this motor,are they different then a standard small block or the same?If different can someone suggest these parts,also was wondering about idler pulleys and belt set up,i do have the p/s pump already but no water pump or front accesories.
Old Oct 1, 2009 | 11:54 AM
NemeSS's Avatar
which ps?
easier to use 6.0 flexplate and spacer with ls starter. this plate configuration also allow use of th350/400 behind ls motor.
